I went out for a ride yesterday and after a few mins of riding I started to have a lose of power, I thought it might be the clutch not working right, I was in lots of sand. Went to hardpack and same issue. I started to get backfire everythime I lifted off the gas. My display was also losing brightness, Like the back light was going out. I limped it back to the truck and came home. Did a compression check today 140 and 145 psi WOT. the 1 spark plug did not feel tight. I also found that the wires on positive terminal was loose and the air filter was full of dirt, plastic and sand. Is that compression ok, anything else you think i should check. The machine has 5400 miles on it. I kinda want to just buy a reman engine and drop it in. Also how do I know if the fuel pump is good?
