Leaning...
4K views 25 replies 11 participants last post by  RMR Man
My rzr is leaning and I cannot figure it out. I have disconnected the sway bar. All 4 tires have the same pressure. I adjusted the shock preload on each shock exactly and it still leans!!! Any suggestions?
Measure all the shocks and see how close the fronts are and how close the rears are to each other. Drive the car. When you are stopping. Try to let it come to a rolling stop and not a brake stop. Then Measure again.
I ride fast hardpack trails and also do some short course racing. It only has 650 miles total and I have tipped it over and bent the stock roll cage. I just put brand new 2.0/2.5 cognitos on and before I installed them I made sure the preload was equal and there is no spring sag. When I am looking from the rear, the driver side bed rail is 2-3 inches lower than the passenger side so that rules out the gas tank.
remember the gas tank is on the passanger side, if full thats alot of weight when no ones sitting in it. also i recall an xp having a leaning problem on here and its turned out that polaris put a front spring onto a rear shock
Frame is bent
That's what I was thinking. Sounds like it may have come back onto 4 wheels really hard. In theory, if your RZR weighs 1200 lbs, and it comes down onto all four wheels from 60" in the air, then you just dropped 600 lbs of weight onto the suspension from 5 feet. All of that leverage will also compound the hit. I think you either bent the frame, or bent the A-Arms, or both. I would not drive it until you find the problem, and repair it accordingly. Just my .02
#25 · (Edited)
I would start by obtaining 4 jack-stands, exactly alike, then jack-up your RZR on a flat surface (such as your garage floor) and place 1 jack-stand under each extreme corner of your frame. Be sure to measure each jack-stand to make absolutely certain that it's extended-length is exactly the same as the others, and you may have to remove your belly-pan so that the frame is resting directly on the jack-stands. It is important that, after jacking-up your RZR, the laterally-positioned (side-to-side) jacks are contacting the frame in the exact same positions, and that the frame, at each of the 4 supported corners measures exactly the same heigth from the floor. If, at this point, your RZR is "rocking" a bit on the jacks and won't sit absolutely flat, that's a good preliminary indication that the frame is twisted.
Ok, now pull all 4 wheels and carefully measure the distance/s from the floor to the center axle-stub/s (in the center of the hub/s). The 2 front ones should measure the same as each other, and the two rear ones should measure the same as each other, but the front and the rears probably won't measure the same as each other. If one of the two rear floor-to-hub-center distances is different than the other, or one of the two front floor-to-hub-center distances is different than the other, then there's a good probability that your suspension-arms, front and/or rear are bent or tweaked, and by comparative-measuring, you should be able to determine which one.
Long-winded, but I hope this helps........
Cheers
