This post is going to be long so I apologize in advance. I just finished my install on the Roktek 3" lift today which went extremely smooth. The only problem I have is I don't feel like I got the amount of lift advertised at all.
Pre lift I was 9.5" in front and 10.25" in the rear of GC. After install I am currently at 11.5" in front and maybe 11" in the rear of GC. This is after taking the RZR out for a ride. When I first lowered it on the ground after install I had 14" of GC in the front and I was ecstatic but that all went away after a ride around the neighborhood settled out the suspension.
There are several things I would like to discuss. Number 1 my RZR is a 2008 model with the original stock springs so I'm 100% positive they are sagging like my grandma's tits. Before I put the lift on I had my preload adjusted at the 3rd notch. I had also recently installed new rims so I'm sure my measurements were a little off because I hadn't taken the RZR out to let the suspension settle after being jacked up.
When I installed the lift I decided to lower the preload down to stock because that is what Roktek recommends. I'm sure that had an effect on why my lift results weren't what I expected.
Now here are my questions. Are my lift results normal for a 2008 RZR with stock suspension and no preload? If they are then is it acceptable for me to adjust my preload back up to say the 3rd notch? Finally, if I install HL springs in conjunction with the Roktek lift should I take out the 2" spring spacers in the front that came with the kit or should I reinstall those on new springs?
