Installing Zbroz Springs
3.5K views 12 replies 9 participants last post by  wishiwasfishin2
Thanks to RockPeakUtv for getting me a good deal on the springs. Ordered Monday night and FedEx showing they will arrive today. Colorado to Texas, that is quick turnaround.
Any words of wisdom on installation? Will be trying to do myself in garage. Never messed with springs, looks easy on videos.
The front shock divider shows to go on upside down to function as the crossover ring. I currently have rzr aid tenders and trying to get an even better/smoother ride. Do I do anything to this divider to accomplish that goal?
Any advice on install or setup will be appreciated.
@wishiwasfishin2 thanks for the plug! Have you read this thread?
I highly highly recommend the exact ratchet straps in post #9. Makes the install and adjustments easy. Make sure you clock the springs per the instructions, the spring tips should be on top of each other and not 180° apart.
Nice, love my Zbroz! I posted my install notes, makeshift spring compressors, etc as well:
I much prefer using the ratchet strap method to the spring compressor personally.
I bolt the base of the shock assembly down and then use three straps evenly spaced around the spring.
Weather finally permitted me to do one spring mount today. Was easier than I thought. Will be Sunday before I can do the rest. Hope front is as easy.
  • Like
Reactions: True K30
