If you could pick just 10 tools to carry...
12K views 34 replies 28 participants last post by  houk88
Just bought a '16 1000XP today and it will be used mostly for wandering about, exploring and just general farting around. Would like to assemble a basic/small toolkit to use for the most common repairs. I intend to keep a spare drive belt, so would like to know which tools are required to change that, other than the obvious from looking at the outside of the case.
Given that, if you could only have 10 tools, please list them in order of priority:
1.
2.
3.
4.
5.
6.
7.
8.
9.
10.
I never go ANYWHERE without my Leatherman tool. Tools are like potato chips, you can't have just one! :)
I always keep the following in my RZRs:
1) Tools to change the belt are a MUST on a Polaris.
2) Tire plug kit.
3) Air compressor. I also made a T-hose that connects to the compressor, and BOTH the tires at once, using clip on air chucks. That way not only can I equally fill two tires, I can also just connect one chuck to a good tire and pump it to 30psi, then when I hook the other chuck to a tire with an unseated bead, I have an extra boost of air to try and seat the bead - rather than just relying on the air compressor alone.
4) Small tool kit of 3/8" sockets, wrenches, pliers, flip flop screwdriver.
5) I keep a tow strap, mule tape, folding shovel, spare belt, and winch recovery kit that has clevis, snatch block, and tree straps in it as well.
6) Toilet paper, aka Mountain Money, or Dune Dollars
7) Water bottle, and a spare lid with a small hole drilled in it. I screw the lid with the hole in it onto the water bottle, and when I squeeze the bottle, it squirts (pressure washes) the sand or dirt out of the tire bead, so I can reseat it. Plus, you never know when you might need some water.
8) Small flashlight.
Top Ten:
1. Belt change tools: Broken in belt, 1/4" drive ratchet, 6" extension, 8mm socket, Polaris clutch tool/shock spanner, Scotchbrite pad and 10mm open end wrench to remove zerk fitting in order to remove the clutch cover.
2. Tire plug kit with air pump
3. Mini battery booster
4. Flashlight
5. Scissor jack, 19mm impact socket, 1/2" drive ratchet and spare tire.
6. Glock folding shovel
7. Sven saw and small Gerber axe
8. First aid kit
9. Duct tape
10. Tow strap
I always carry a Leatherman on me. The RZR always has a fire extinguisher, a fixed blade knife, a personal locater beacon, a GPS, leather gloves and water. I also carry a complete tool kit, including spark plugs and a few other items that fit in my rear box.
#5 · (Edited)
1.Hi lift jack cut down to to fit. You can use as a come along as well
2.Tow straps
3.shovel
4.Axe
5.First responder basic medical kit
6.Small tool box with basic tools,belt,bailing wire,duct tape,paracord-etc.
7 . headlamp
8.gps - two way radio
9.water
10 - toilet paper
I carry way more than that. Don't forget the fire extinguisher.
Better to be prepared.
Forgot - I have ccw permit so one of my pistols would be #1 for me
Hey Tim, over the many miles riding and guiding in the backcountry, here are the things we try to take with us:
1. Extra Belt (you will need Polaris part#3211180)
2. Belt Removal/Clutch Compression Tool
3. Misc. Basic Tool Kit that include assorted pliers, screw drivers, wrenches and sockets, a knife and also hand tools to remove the clutch cover or SLP Clutch Cover Removal Tool
4. Scissor Jack
5. Tire Plug Kit
6. Tow Strap
7. Ratchet Strap
8. First AID Kit
9. Duct Tape
10. Fire Extinguisher
(Not necessarily listed in order of importance)
I'm surprised that with Hunterworks being one of your resellers, you make certain to detail a Polaris belt, rather than the Gates he promotes so much on this site...
Ya there thinking you don't know about hunter works the belts the sell are great same or better than stock I tested myself 2k mile
Sent from my iPhone using My finger
I bring combo tools like leather man, tow rope, weapon, socket set Allen set and a spot gps locator press a button and I get found
True, but I have two RZRs, and the toilet paper I don't count as a tool. ;)
#20 ·
Re: the Belt Removal/Clutch Compression Tools ..... which of the four kits is the proper one for a 2016 570? Thanks in advance.
Product Information:
Part # Description Retail Action
20-217 Belt Removal/Clutch Compression Tool (3.6", 91.5mm roller cutout to roller cutout distance) 29.95
Add to cart
20-302 Belt Removal/Clutch Compression Tool (#20-217) with Sheave Clamp (#20-161) Kit 39.90
Add to cart
20-306 Belt Removal/Clutch Compression Tool (3.1", 78.9mm roller cutout to roller cutout distance) 34.95
Add to cart
20-307 Belt Removal/Clutch Compression Tool (#20-306) with Sheave Clamp (#20-86) Kit 44.90
Add to cart
#21 ·
We sell the belt removal tool by itself:
Part# 20-217 and 20-306
We also sell it as a kit that includes a sheave clamp for holding the primary clutch open along with the belt removal tool:
Part # 20-302 and 20-307
All new slide block style clutches found on the 2016 models will use part number 20-306 belt removal tool or 20-307 if you want the combo.
On other RZR models, it is best to inspect the clutch first and see which secondary you have.
For RZR models up to 2015 with the stock Rapid Reaction secondary clutch (no outside rollers), there are no belt removal tools available. (2009-14 standard RZR and 2015 900 trail)
For models with the TEAM Tied Secondary clutch (visible outside rollers), there are 2 potential tools. Most models up to 2015 will use the older tool (Part# 20-217, or 20-302 for the combo), but TEAM made an in-run change on this clutch in 2015 and so some 2015 models or replacement clutches purchased 2015 or later may require use of the 20-306 tool or 20-307 combo.
A quick and easy reference is whether you can see the roll pin holes that hold the roller assembly in place. If you can see them you need Part# 20-306 (or 20-307 combo) You can also measure the distance between the roller cut-outs to know for sure:
#22 ·
as far as tools, i try to ride with the guys who carry EVERYTHING lol
but for me usually -
Spare Belt
Tire patch Kit
tools to change belt
a few torx bits for any rattling parts
tow straps
water
weed
a lighter
Rain Gear
everythiing stuffed in my glove box, its pretty much a nightmare to get 1 thing out hhaha
#29 ·
I carry way too much stuff to list here, as I ride a lot by my self. But some things that come to mind that haven't made the lists above yet that I carry: Spare fuses, big flat blade screw driver or pry bar to remove Cv axles, spare C-clips for CV axles, fire starter, breaker bar/ratchet, extra couple feet of 12 gauge wire, handfuls of zip ties, machete, HAM radio, rain ponchos, 6'x8' tarp.
#30 ·
Ok here are my 10 tools since the thread says 10.
1. 15 mm combination wrench
2. 17 mm combination wrench
3. 15 mm 3/8 drive 6 pt deep socket
4. 17 mm 3/8 drive deep socket
5. 3/8" 3/8 drive deep socket
6. Short 3/8 drive extension
7. Long 3/8 drive extension
8. Dewalt 20 volt 3/8 drive impact wrench
9. 10" vise grips
10. 3/8" drive socket that fits your lug nuts.
I carry way more but since the list is limited I think these would handle 95% of what you would need on a properly maintained machine.
#31 ·
1. Spare Belt
2. Tool kit with torx bits, sockets, and clutch tool
3. 12V Air Compressor
4. Tire plug kit
5. LED Flashlight
6. Compact .45
7. Raingear
8. Tow strap and spare rope
9. Storage box with small cooler, cups, TP
10. Machete
I need to get a first-aid kit in the machine. I have my Search & Rescue day pack that I use, but it takes up a lot of room. I need a bigger storage box. I think a first-aid kit is a must for every machine. You NEVER know what may happen and I have had to bust mine out for minor injuries to other riders.
