Hi all:
My 2013 570 is having intermittent idle problems. It would start and idle like a champ but started stalling an hour or so into a ride. Runs fine otherwise and no fault codes showing up. The stalling is intermittent.
A couple of months ago I found the TPS output voltage slightly off. Thinking this may be the culprit, I adjusted it to get the specified 0.46 Volts between the orange pin #1 and green pin #2 wires (backprobing the wires w/ connector on the TPS). Still experienced the intermittent stalling at idle once into a ride. I checked the TPS voltage again today and it's gone wacky - the same two wires (orange/green) have 2.88 Volts (!) between them (key on, engine off, not touching pedal). Further testing shows the purple wire is not getting the 5 Volt reference signal I think it's supposed to have, instead it is continuous with ground (and 0 Volts w.r.t. ground). I checked all three wires (orange, green, purple) and they have continuity back to the plug at the ECU and none are grounded out (i.e. these 3 wires aren't broken or chaffing on the frame somewhere). The TPS itself passes all the resistance checks and none of the 3 pins is grounded, so it seems OK. I also checked and reseated the ground bundle bolted to the frame just behind the battery box.
So the problem seems to be within the ECU or upstream of it where something seems shorting to ground? It starts, idles and runs fine but I expect the idle will act up again after some time running. I've seen similar weird "backwards" TPS voltage reported elsewhere - where you get closer to 3V instead of half a volt at the TPS- but no ultimate solutions were offered.
So... what would cause the 5V TPS reference voltage to be grounding out to zero at the ECU? I dread this is another mysterious wire chafing problem somewhere. Any help would be appreciated.
Thanks
Thanks
