I knew I was due for some new springs, but while replacing the front bushings, I noticed one spring is now shorter than the other....
I have the front end jacked up at full droop, and the drivers spring is at least 1/2" to 3/4" shorter, and at ride height, the RZR does have a noticeable lean.
I do not want another set of OEM springs,
so it seems my options are...
1. Makin trax progressive coils, or
2. A dual rate spring kit like at Racer tech?
The dual rate might be more/ "tunable"
I mainly ride forest trails/ fast'ish
and on the dunes, lots of bumps and stuff.
custom cage and some bolt-ons. weight wise.
I currently bottom the back end out often, and have the drivers side lean.
Thanks..
Thanks..
