I understand that removing the sway bar makes the wheel drop to the ground when off camber. This makes one feel like the vehicle better articulates to the ground. HOWEVER, whether the wheel is touching the ground (sway bar removed) or hanging higher due to the sway bar working, doesn't the wheel still have to cover the same amount of travel either way? It may make a driver feel more secure, but there isn't really an tension on the suspension either way until the vehicle returns back to the ground. What am I missing? How does having a wheel drop to the ground without any suspension tension (like when the sway bar is removed) really help anything? It seems to me to be a null effect? As a matter of fact, isn't worse since you no longer have an antisway device during high speed cornering and no "real" or "false" articulation when dangling and having a loose wheel(suspension)during an off camber situation? Puzzling to me...
