How long to install Outkast S conversion?
1.8K views 5 replies 3 participants last post by  barthowes
How long did it take you to install the Outkast S conversion on your rzr 570?
Ray
Depends. Took about 12 hours total including disassembly. Literally 4 of that was because the axles were stuck in the rear and required a lot of work to get them out. Then it took about an hour to get the alignment as you have to take the tires and tie rods off to adjust, ride for 10 mins and check again.
I ordered the Rhino 2.0 axles. I have a 2017 with a little over 1100 miles on it so I believe I should be able to reuse the existing ball joints and bushings with no problems.
I should be getting the conversion kit in the next couple weeks and will hopefully start working on it by June 4.
