There is virtually no comparing Polaris AWD system to another 4WD system. I have taken apart the hubs and learned how they work. Pretty cool the only drawback is no engine braking on the front, once they unload they freewheel. It had a locked front diff, the second part of the system is in each hub, when engaged in AWD the front shaft and diff are spinning at the same speed the rear wheels are but the only way it will engage a front wheel is if the rear wheels spin, if that happened this causes the front axle shaft to spin faster than the wheel is turning, when that happens there is a mechanism inside the hub that turns and throws the outside of the mechanism out and grabs the hub which then causes the wheels to turn. Once there is no more spinning the load comes off the front hub and the mechanism relaxes and releases its hold on the hub. It is an amazing system and works great. Until wear and water gets inside and its starts to lose it's magnetism, I had issues on an old Polaris quad I had to shaft down the hub a little to get the magnetized plate to grab better.
