High Lifter Transmission Part number
12K views 11 replies 4 participants last post by  SuperATV
Can anyone confirm if the part number for a High Lifter Edition Transmission is 1333536? Appreciate any help.
What year are you wanting one from? What exactly are you trying to accomplish?
I have a 2018 RZR 1000 XP 4. I'm going to swap a High Lifter Transmission into.
Oh ok well just a suggestion but for a couple hundred bucks you can regear your current one to the hl gears. Unless you broke yours.
Could you tell me exactly what shafts I need to replace? I've been told that the snorkel gear, reverse chain and a few other gears and shafts need to be replaced.
The rzr hle reverse chain is 1 link wider. If you don’t need it rebuilt right away I would wait for the 2020 Rzr parts to come out. While I can’t guarantee it will happen but the ranger hle has a gear driven reverse so I would think we will see that same style in the New rzr. At least
In the hle. As for an upgraded reverse chain I’d go with a super single. Either from super atv or
I think bio hazard makes one. For the gear reduction you can go with oem gears. Let me
Know what you decide and I’ll look further into the trans schematic to see which gears will get
You the reduction you want.
I want to get a gear reduction in high, low and reverse. At least 20% gear reduction. From what I've read the 2018 1000 XP 4 has higher gearing than the previous year model 1000 XP 4's. I already have portals with 30% gear reduction. I'm running 35" tires and the belt still slips from time to time.
You can do an ace 325 gear reduction or an ace 570 gear reduction. As for the chain I’d get the aftermarket one instead of putting the hle chain in there imo. I’ll see what kind of gear reduction each of those will give you if you give me a few. I believe the 325 gears will lower a 15 xp 1000 27 percent so that gives you a baseline. The 325 gears are like 200-300 bucks.
