High Clearance Front A-Arms and No Front Sway Bar - good idea?
1.2K views 1 reply 2 participants last post by  SSGPohlman
I swapped the front A-Arms to Super ATV and there is no mount for the factory sway bar.
I have swapped the springs out to Shock Therapy dual rate w crossover (big difference by the way).
Has anyone run their Dynamix with no front sway bar? Since I've replaced the springs to a softer upper and stiffer lower, before the crossover eliminates the softer sprung upper spring I have a lot of roll.
Should I just put the suspension in "Firm" for the faster trail sections to eliminate the "roll"?
Or is going without the swaybar just not worth it and to somehow get it back on?
Looking for any advice out there.
