Help! Issues with Gear position selector
Tags
rzr800
4.8K views 6 replies 3 participants last post by  CA 800
The part number is 3234871.
I think your picture is of an 08 sensor.
The connector has 6 wires.
The 09-14 sensor connector has 2 wires.
I would check the continuity between the common (center) contact and high contact to verify internal resistor is bad.
If resistance is correct look for mechanical issue with pins, springs, & contact surface of sensor.
