General's Instrument Cluster (Dashboard)
20K views 43 replies 22 participants last post by  radvans
I love the new Polaris General's Instrument cluster (dashboard). Does anybody know if we can use it on our turbos or the xp1k?
The General's instrument cluster uses the same pins as the RZR gauge for Can Hi, Can Lo, Constant Power, Switched Power, and Ground. I do not know off the top of my head if the analog in pins are the same, but I think High Beam and Fuel Sender are the same. Note that this is true only if your RZR has a 16 pin plug on the gauge. It will at the very least display all CAN message controlled inputs, including engine hours, engine temp, odometer, speed and RPM. Full functionality is an unknown though.
#6 · (Edited)
:popcorn: I want one. Rode in a General last week, loved the new Dash, and instrument panel. Someone please pull the plug and try it out. I just called the dealer, you can get the whole instrument cluster, and housing setup for $390. They didn't know if the plugs were the same. Electrical part no returns, said they could have it there in a week.
Lol...He's borrowing my tubing bender and notcher right now to build tree kickers, and I helped route some wires for his new rock lights, as well as installed a clutch kit in their highlifter rzr not long ago. I think I'm entitled to a little tinkering.
Pin-outs for the General gauge:
1: CAN-HI
2: CAN-LOW
3: Switched Power
4: Constant Power
5: Ground
6&7: Turn Signals (12V input)
8: High Beam (12V input)
11: Analog Fuel Input
12: Ground causes the unit to turn off the backlight and indicators off.
15: Ambient air temp sensor input.
The gauge is automatically set to function on the vehicle it is first plugged into, so if you take it off a General it will always assume it is on a General. Digital Wrench should be able to set it to generally match a different unit if it is a 2015 or 2016.
All contemporary Polaris vehicles used the same CAN messages and all the Rzrs use the same basic wiring as I understand it, so they should work on the non turbos just as well. The only thing that might be an issue (depending on the model installed onto) is the fuel gauge (some are CAN based some are discrete, and the tank fuel curve is different between some models).
#28 ·
This is good news! I would want to mount on the steering column so it moves with the wheel, but I have the Ryco turn signal/horn stalk and there might not be enough room for both.
Now we need to get a vendor to do (relatively inexpensively!) a new upper dash that makes room for the General instument cluster and leaves a flat area where the original speedo is in the center for mounting GPS/iPad/radio, etc. :ride:
Marv
#30 ·
I was just thinking about this also. I think some work in CAD (Cardboard Aided Design) :rofl3: is called for. Make a template to cut out and fill in the round hole with wood or metal or heavy plastic so that a RAM or other mounting system could be screwed on and mount whatever you want in front so you don't see the original round instrument hole. For me that would be an iPad to use for navigation. With the RAM it could be adjusted to an angle left or right and up and down. :ride:
Marv
#34 ·
I really want to see someone complete this mod!
#36 ·
I was just sitting in a General at my dealer as I picked up our car from the recall work. I REALLY like the instrument pod. It looks like there would not be room to have my RYCO street legal turn signal stalk mounted as well as the new pod. And I do think there would be some plastic cutting involved. Somebody show us how it works please? :ride:
Marv
#38 ·
Subscribed
