Gas cap problems with doors
11K views 37 replies 23 participants last post by  cyclereckr
My gas cap is tight against my pro armor doors. When I try to turn it, it turns one click at a time while the door post goes in each "indention" On the cap. I really don't want to relocate it. I may try to pull the door away from the cap. Has anyone else had this problem?
Mine is the same way real tight a pain in the ass to remove
Yup, hands are getting a bit arthritic, getting to the gas cap with Pro Armor doors was making it even tougher.
So I designed this wrench and cut it from 10 ga steel. Seems to work just great!
I cut the nozzles off my gas cans and only use a "simple siphon" and tygon hose. Sure beats having to hold a gas can, needing a funnel. Just a couple of quick pumps and fuel flows. Just leave my Holz gas can in the Polaris rack all season.
Here's my wrench:
Thoughts?
Pirate
I'm sure you can push out the bottom door frame 1/4'' with the adjustment bracket under the seat and clear just enough the gas cap. I know i have at least 3/4'' adjustment on mine.
If not... it's just alum. tubing, a small dent with a heavy hammer will do it. It in the inside anyway, nobody see that.
I've got an 800 S LE. Pro Armor doors. Had the same problem, when I first installed the doors.
Fix:
Open the door so it is perpendicular to the side of the RZR. Lift up on the bottom of the door, this will bend the door frame away from the gas cap.
#20 ·
I had to same problem with my gas cap on my 2012 Razor 800 when I put the Pro Armour doors on it. I could not get my gas cap off. I loosen the door enough to get the gas cap off. I ground the notches off the gas cap with my grinder. Tighten the door back up and put my gas cap on. The cap is rounded and I can get my gas cap off now
