Front sway bar end links hitting lower a arm
6.6K views 22 replies 8 participants last post by  SuperATV
End links are low enough to hit lower a arm while driving. Do I need shorter endlinks?
Similar Issue , moved to links inside maybe turn bolt around too.
#20 ·
One of my heim joints on my sway bare links was bad and had to wait for a new one so I rode with out the sway bar link attached and I'm a high speed trail rider, I love to go fast 😁 And there was so much body roll.
That was the first time I removed it.
I would never remove it for high speed stuff I'm thinking of getting a front bar, Weal see though.
#23 ·
With our forward offset arms, you have to move the sway bar to the inside to avoid hitting the offset HC arm. Or....just take them off run it. Most of us in our area throw the sway bars in the scrap pile before it even hits the trail. Unless you're at WOT all the time on tight trails, you may find that you like the ride and increased travel on rougher terrain.
