2020 Pro Ultimate. What type of spanner do you use to adjust the front shock preload? A crows foot style? From? Thanks!
This is the tool I got with my 21 RZR Trail ultimate 900. Its also is used for changing the belt2020 Pro Ultimate. What type of spanner do you use to adjust the front shock preload? A crows foot style? From? Thanks!
Pretty cool..I didn't remove my front shocks to adjust.
There is definitely no room to use the tool on the passenger side without removing the shocks.
Basically, with dynamix, make sure the suspension is in soft mode, key on. I had my wife and daughter both sit on the front to weigh it down as much as possible, then wrapped a ratchet strap through the spring over and over then tightened it to the lower arm as they bounced....
Then, jack up the vehicle, and I had a bit over an inch of space between the top spring and the preload ring. Break it loose with a punch and I was able to adjust it by hand.....😁
