floor mats by Tread Liner
4.8K views 9 replies 6 participants last post by  Clothier
I just got my new floor mats from Tread Liner. I wanted to keep the dust down as much as possible. That means that the mats need to fit REAL close, to seal the holes in the floor. The Tread Liners didn't fit good - THEY FIT PERFECTLY. It's not often that I'm amazed about the quality of a product, so wanted to give credit where credit is due. I just wish someone made a soft, flexible rubber mat to go under the seats, to seal off all the holes there. Will probably use duct tape. Ted
I bought one just like the UTV Inc. sheet.
But then put the loop side of Velcro all the way around the edges and used contact cement and a stapler to help hold it on.
I used the hook side of the Velcro to the plastic floorboard. Again used contact cement and then pop-rivets about every 4".
so now it doesn't keep moving, and its easy to remove to get to things.
Pirate
Thats a good idea Stuart! Right now I just bave mine attached using the oem plasitic rivots.
I love the Treadliners when I am working on RZR.
I can't tell you how much time I spent looking for dropped nuts & bolts . . . they always found thier way thru a drain hole and rolled across floor pan.
It helps alot!
