In my business, we do a LOT of oil changes. Fortunately, lots of people keep an eye on their oil level. That's GOOD. Whenever checking the dipstick, the vehicle needs to be as level as it can be, both front to back, and sideways. Also, if you check your oil just after shutting down the engine, you will have a bunch of oil in the oil galleys and stuck to the crankcase walls, not at the bottom of the oil pan. Conversely, if you let it set overnight, the oil level will be a bit higher, because of all the oil that settled into the oil pan over time. So, it's a little subjective. Basically, with any engine, if the oil level is an eighth of an inch or so high, it's not going to destroy your engine. Consider what the oil level is when going up a 60 degree hill, or side-hilling. Lots of changes in where your oil is located at any given time. Totally confused now? No problem. We all are.
