Diagnostics ERROR CODE 26
1 reading
20K views 36 replies 18 participants last post by  Madera Calif
It's on my 2010 rzr-s. My manual doesn't show an error code of 26, and the shop where I bought it from doesn't know what it is. Machine run's fine, no apparant problems. I removed the negative battery cable to reset the diagnostics, ran through it again, and 26 pop's up each time. Anyone had experience with this one?
Friend of mine has a new 2010 Orange Rzr S with 600 miles and 52 hours and last night was running 750 RPM at idle and sounded like it was missing one one cylinder and making a chatter sound at idle. At speed it sounded normal. Read the codes and received a (51) five blinks and one blink, then a numeric 26. Does anyone know what causes this code and how to correct this code?
implausable? does that mean the dash thinks the speed sensor is making stuff up? hehe.
pull the speed sensor, follow the wires to the tranny, clean it up, check for bad connections, bare wires, etc. if it still does it, replace the sensor. i cant remember if the speed sensor is under oil or not. (i.e. i dont remember if you have to drain the tranny to pull it or not)
#20 · (Edited)
I love it when you ask a question on these forums and you get a smart ass remark back. Yes I read the info and did so still getting code . Any other options ? Before I take it to the dealer:rm_thumbdown:
I have read on other sites where they have replaced the sensor as well and no fix yet. Maybe somedody has some insight that as had this problem?
#21 ·
Did you try disconnecting the battery to clear the code......
#31 ·
OK guys. Not sure if mine is the same as yours but here it goes. I too was getting the code 26. I have only had it out once and barely have any miles on it and I was getting the code 26. I was pissed. Anyway. I was wondering if it had to do with the paddle tires and how it was performing in the sand. So much wheel spin etc. I tried to clear the codes several times with no luck. I put the stock tires back on it. Ran it up and down the street a couple of times and then I cleared the code. This time it took. Was it the paddle tires and diff ratio that could have caused the problem. Dont make sense I know but it worked. The speedo worked the entire time too which was wierd. You wold think with this code that would have been irratic. Anyhow, Worked for me. Thought I would share. Im going to dumont friday so we will see if it stays clear. If not Ill do it again.
#33 ·
no prob, hope it stays clear. If not does anyone have a solution yet? Seems like there is a problem especially when it happens right off the show room floor 17g's later and bam. Im still pissed but oh well. Ill keep my fingers crossed. How did everyone else get the code to clear? With the code did anyone show any performance issues? If it doesnt effect performance or anything then I say screw it and ride:ride:. JMO
#36 ·
Hello, Seems to be no resolution on code 26 ? I get code 26 on my 2010 RZR-S and it will sometimes not run at all at full throttle and idles at 850 instead of near 1200 rpm. When this happens it seems to run fine for a while again if I just turn it off and restart it? Also this machine has always seemed slower than my 2008 RZR.:( Any thoughts? Thanks, Nick
