Many will discover that their yokes are slightly bent 'twisted' a few degrees.
its not obvious until you pull the original joints out. Take an appropriately sized socket and push through the yoke. Does the socket indicate yoke alignment?
Installing a good new bearing in a twisted yoke is a recipe for failure. And folks wonder why they continue to loose U Joint bearings. By the time your first bearing goes out odds are your yokes are twisted.
I also agree with the previous RCV shaft or same style CV shaft. DO NOT use a solid 'pillowblock' style bearing. There is not enough play to allow the CV shaft to shift. The rubber isolated 'Toyota' style carrier is a much better choice.
it also allows 'end play' which your diff and snorkle gear will appreciate. The entire shaft assembly is constantly moving angles and lengths. A solid pillowblock interferes with this.
Anyone want to buy a used SuperATV Carrier Bearing with a grease whip pre installed?
