I tried to check my compression with the $40 tester from autozone and i got a reading of 90psi on both cylinders. the bike idles and runs great. I was just checking as a precation and something to do. It is an 09 rzr le with about 650 miles. The manual sayes the service limit is 150-180. I only got to do each cylinder once and i ran the engine about 10 minutes before checking to warm the engine up. On the 2nd cylinder it blew a whole in the hose to the gauge. I also cant be positive that i got the hose tight on the adapter because i could not get a wrench on it so it was only hand tight on the o-ring. My question is, wouldnt i notice an oil burning smell or even see smoke, or a situation where it would not idle or something if i truly had a compression of 90 psi or does it sound like the tester was crap. Thanks in advance.
