Whole story, had service at dealer, new air filter, rode Ocala national forest, checked air box had a little sand in it. Changed to Uni filter and went to durhamtown and adventure world for a few days. Machine developed an odd noise so when I got back took it to dealer and requested a compression test and fix whatever is wrong. Replaced front prop shaft under extended warrenty, also 8 bushing on A-arms. Compression test showed 90 lbs, specs say ok if between 80-120, will take in and have retested in 14 hours before trip to HM. I know nothing about compression so I don't know if thats a sign its going bad or if it could be normal. Any comments from you guys that know something about this? I realize it is in specs but it is on the low end.
