I'm running into a small problem while attempting to install my Rubberdown lift kit (although I'm sure that this issue is applicable to pretty much any kit).
The instructions for the rear are to jack the Rzr up, remove the lower shock mounting bolt, install the lift block on the lower shock mounting point (on the A-arm), and then attach the shock to the lift block. The problem I'm running in to is that the top holes in the lift block are now about an inch higher than the lower mounting hole on the fully-extended shock, so I can't attach the lower shock to the lift block.
I suspect that the solution here is to either 1) use something like a spring compressor tool to compress the shock assembly enough to mount it to the lift block, or 2) before jacking up the Rzr, constrain the shock from fully extending, with something like several zip ties through the coils.
Can anyone share their experience with how they addressed this issue? I'd prefer not to go out and buy spring coil compressors unless absolutely necessary. Thanks.
