Code 84-2
1 reading
12K views 3 replies 3 participants last post by  bubbazwv
Hi code 82-2
I figured out my other code and it reset itself after driving 4,000 rpm 30 seconds .
now 84-2 is still on
No speed o miter reading
No p r n l h reading of shifter ….
Any ideas ?
16 1000s
Sounds like a relay. I would pull the fuse box cover and inspect. Check the fuses and try swapping some of the relays around to troubleshoot. I think there is a main accessory relay that would be most suspect. Also check your battery terminals are tight and chassis ground is good. Verify power at the bus under the hood.
