co2 setup
3.9K views 19 replies 12 participants last post by  Col_Sanders
Anyone tried this one? I have always purchased powertank stuff but there 20oz kit is ridiculous IMO. This setup is cheaper and has the regulator as well. Going to order one soon. Just thought I would see if anyone is running this one with good results.
And at under $100 shipped its hard to pass up.
ok, i'll bite.
i dont understand the purpose of using Co2 on a RZR.
My buddy and I did this. I definitely regret spending the money on it and wish I would have bought one of the small compressors that plugs into the cig lighter. You don't have to worry about running out of air.
Hmm... pics? where u at in Co?
why not use N2 if your going to use exotic gases for your tires.
get an N2 tank for $26.00 and a regulator for about $80. refills are relatively cheap from airgas
if thats the rout you want to go. or a Viair pump for $55.00
#20 ·
Those work fine for airing up a tire, but to seat a bead these CO2 setups work much better. The only other thing you need is a ratchet strap. Sure there are tricks where you can use gasoline, starter fluid, etc and a lighter, but I'd rather not burn my beard off. :scared2:
The Power Tank regulator I have is adjustable up to 160psi but I think the adjustability is kind of pointless unless you are going to use it for running an impact wrench. The models with a single pressure would work fine for tires and they are cheaper.
