I'm wondering if anyone knows the best clutch kit for Mudding? I want a kit that will make it feel like im about to pop a wheelie when i take off.
Does this mean an 11% reduction in top speed? Or does it offer the best of both worlds?From what I read I decided on a CV Tech. Not sure how many others also use a Snowmobile clutch like Airdam CV Tech but that was a huge selling point for me. CV Tech is so darn simple with only one bearing in it. The clamping force is far superior to the stock clutch. Because of the later engaging through out the rpm range it works out to a 11% "gear reduction".Changing the weights and springs is a snap. If you want axle breaking take off or smooth engagement it is very easy to set it up.
