Cleaning clutches...what are yall using?
1 reading
15K views 11 replies 7 participants last post by  jaylyon
Just wondering what everybody uses and how you go about it. Prob gonna put a new belt on and figured id clean the clutches.
B.A.M.
#10 · (Edited)
But, while your blowing all the dust out of your primary clutch:
Make sure the three rollers that the weights bear on will roll smoothly.
Make sure the rubber (?) spacers on either side of the rollers are in good shape.
Make sure the spider isn't getting grooved by the rollers.
Check the bolts through the weights are not getting worn on one end. They'll let the weights rub on the spider and damage it.
Check the bearing and make sure its still turning smoothly.
Keep in mind that the Primary clutch acts like a fan. It draws air in from the air box blows it through the CVT housing and out the exhaust duct that's located right above the throttle body. Thus the Primary clutch is actually a "consumable".
Just thoughts
Pirate
I blow mine out with compressed air, then clean the sheaves with brake clean on a rag, then sand them with 400 grit or scotch bright pad, then I clean them again with brake clean. Don't use any thing on them that will leave a residue. Also I clean my belt on hot soapy water.
