I recently had a overheating incident riding my 2016 900 Trail. My temperature light came on so I changed the cluster mode switch to temperature and it was reading 245° so I immediately turned the engine off! I also noticed that the fan was not running and that was of course the problem. After checking the fuses in the fuse box they were all good so I decided to swap the fan relay with the EPS relay knowing I can do without power steering. Sure enough the fan came on and my power steering failed to work so I was able to continue back to camp without issue. When I got home I was able to order four identical relays on Amazon for around $14. I replaced the relay that was bad and everything seems to be working fine again for the exception of having a check engine light with a code of 0 746 4, that will not go away even after removing the battery cables overnight. The only information I’ve been able to find about this code is the 0 means that this is the only check code it’s throwing and the 746 refers to the Rear
Differential Output, but I cannot figure out what the 4 refers to in the code? Awd mode works fine and turf mode works fine also.
I called 2 different dealerships and all they had to say is “bring it in, we can’t speculate what’s wrong with it without seeing it in person.” In layman‘s terms that means we’re not gonna give you any information without you paying us for it!
Any help with this would be greatly appreciated.
