Here's a preliminary pic of the end result of changing the factory cluster's backlighting.
I will post up how to do this with pics, instructions and a material list.
I am not interested in doing this for anybody because I don't want to assume the responsibility if anything happens to the cluster.
It is a straight forward install for anyone who has the skill and the tools.
You will be working with very small surface mounted devices(SMD) that are as small as a nail head. You will have to have a fine point temperature controlled soldering iron and needle tweezers. You will also need a hot wire knife to open the case. A Dremel will work but you need to be very careful not to cut too deep.
You are looking at about $7 in parts and less than an hour.
Once I have the instructions ready I will post everything up with pics.
