Ahhh... This is exactly the info I was looking for.
I was wondering what that orange wire connect to... well... Nothing ... was for. It's awesome that Polaris provides a switched power source so we don't have to go find and tap one ourselves. That said, that Bus Bar was put there primarily for their Accessory harnesses, but it's a bit of a joke IMHO. I'll be removing it and tossing it in the trash.
One thing I haven't heard (well read) much about on this forum is the need for fusing your accessories. Again, IMHO, all accessories should be individually fused and if you want them switched with the ignition it should be through a relay. Not only does this protect your equipment but also when you do have a problem, it is a lot easier to isolate.
I'll be installing an Relay controlled Accessory fuse box using that "Acc" wire as the relay trigger. I'll post up details when I do.
Pete, I assume you ran a ground wire as well? Have a closer look at the fuse. Sometimes a break in small amperage fuses are hard to distinguish.
