Broken, cracked or burned through header pipe????????
14K views 14 replies 8 participants last post by  JP2024
As stated, my header pipe is broken or whatever. Are there any tips or shortcuts to replacing this.
I will be replacing with a stock head pipe.
Thanks in advance. Unit has just shy of 15000 (yes, correct number of zeros) miles.
It’s a tight fit and you will use a lot of cuss words. Best way is to remove interior plastic firewall panels.
You can do it without but you will use every 10mm long and short socket you own plus every true and size of 10mm wrench. And that’s just to get the heat shields off near the exhaust flange.
then you need long Allen sockets to get between the header pipes. I would suggest a new exhaust gasket while you are at it.
I just removed the exhaust off my 18 RS1 which is same motor and exhaust. And I did t remove all the panels, took alot longer than it should have.
If you are any where near Mesa I’d gladly donate my whole exhaust to you just to get it out of my way. It does have a gutted out cat for better flow and was only on the machine for 1000 miles.
Thanks, but not near enough to Mesa. And I found one in stock at Rocky Mountain ATV And the gaskets.
One day expidited shipping I should have it by Wednesday!!! LOL.
Doing this is a huge PITA for 75 year old hands! LOL. If I weren’t in kind of a rush I would have taken it in someplace, but heading out for Quartzsite in a few days and want my machine with me.
Check all your motor and transmission mounts, I have blown 2 headers, and both times I had either a broken motor mount or a broken transmission mount bolt located just behind the muffler and I read in the forums that was a common cause of headers blowing out. The 1st header I replaced, the second one I welded it closed and have done two long trips this season without a problem. I have a back-up welded/repaired header in my toy hauler...just in case it blows open again.
Update…….nothing had to come off the rear of the machine…..muffler and corresponding heat shields all stayed in place. Just took seats out, removed firewall panel, removed the two flange bolts, removed the 6 allen head bolds from flange at engine and the header pipe came out through the passenger compartment. EZ PZ! All one has to do is just do it! LOL.
No engine mounts or trans mounts broken or anything………I guess I must have just used the machine too much when it was new! LOL.
According to Fedex tracking number, the new goodies should appear today. Then I get to reverse the process.
While waiting, now is the purrfect time to clean the engine below the oil filter. I find it impossible to get things 100% clean and dry when changing the oil filter, so it had built up some dirt and grime after all the miles I put on! Now that can go away and I can start building up a bit of new dirt and grime!
Updat #2. Decided to do an oil change while waiting on parts. Drain plug and hole in skid plate barely line up! Hmmmmmmm……….go back and re-examine motor mounts. Guess what I found upon further review. Bolt in outboard, port side motor mount sheared off! Yup, that would cause my issue. All good now! LOL. Old farts can’t see the obvious when right in front of them!
Update #3. Got motor mount fixed, Fedex shows up with new header, got new header bolted on.
Now all I gotta do is put the plastic panels back on, finish the service job, have a sip or two of Jameson and have a good cigar! Then go ride the next day!
