21 - 40 of 44 Posts
Yep, that's what the dealer said. Learned something for next time.
BTW...the master cylinder is in a PIA location for checking level and refilling. But I can see where finding a good location wouldn't be easy on these newer cars.
Something I have noticed that I’d like some others to answer if they can. The less miles the better in this question. Look closely at the brake rotor and see if you think the pads are wearing on the rotor in a way that may not be quite flat. Seems to me that the wear mark that the pad is leaving is towards the outer portion of the area they would make contact with. Makes me wonder if we’re dealing with an alignment issue of the pads. So in this instance, some wear time will make things better. Just a thought.
Had the same issue on mine , faster and tighter the worse it was . Also took back to dealer and they stated it was also air in the line issue . We were all thinking master cylinder at camp time will tell
Picked my car up today. Brakes are nice and firm now. Going to the dunes right after Christmas to ride, will see if they stay good.
Just bought my 4seater s and brakes do the same thing. Pedal feels soft and goes to floor every once in awhile. Also left rear shock resivoir rubbing spring.
My friend's Turbo S seater was doing the same thing with the brakes. We bled the brakes but the pedal went back to being mushy. My other friend has no issues with his brakes on his Turbo S 4 seater.
Two seat 19 turbo s model not in their model list on that link.
Not going to worry about it.
They have my address.
Just got my 2019 Turbo S 2 seater a month ago, pedal would go to the floor right out of the dealership, bled the system with some new DOT 4 brake fluid (which looked different than the factory fluid) pedal felt much better after that. I think when they bleed from the factory they do not do a good job, also kind of looks like they don't use DOT 4 from the factory (which won't really affect pedal feel just boiling points).
Anyone know what the "fix" really was?
Got mine done today. Dropped it off had breakfast got a couple errands and it was done. They left the instructions on the seat.
Sent from my Pixel using Tapatalk
Was there any more info on pages 1-3? I noticed you had pics of 4-7. Thanks for the info... I was real curious what they were doing.
21 - 40 of 44 Posts
