We have had our turbo's for a few weeks now and getting everything lined up for proper testing. We will have excellent performance upgrades for those looking for the most possible power. Right now in stock from we are between 146-148hp. Here is a quick run down of what we have in the works for our state of the art Superflow 902 dyno center:
Programming: Custom turbo programming with the Bully Dog GT. The GT will allow various tunes to be purchased for different power levels and fuel types. Our stock tuned Arctic Cat 1100 turbo sleds have been dominating for years now on grass, asphalt and ice, so we know how to tune these stock turbos for all they are worth... especially on pump fuel. We know that it's important to have an option to tune your machine down as not all pump fuel is created equal, and sometimes you don't want the person in the drivers seat to have full potential. With one easy device we will have many tunes available with different hp levels on pump fuel, and higher HP tunes for race fuel. This device will also double as a gauge to monitor boost, engine knock & many other parameters. You will also be able to data log any issues you may have and review them later, and read/erase trouble codes on the fly. Don't want any of that? Program your ECU and leave the device in the garage. Taking it to the dealer? Flash it back to stock within minutes. With other flashes you don't have the ability to see whats going on, or do anything about it if you have an issue.
Exhaust: We will have a simple slip-on exhaust, as well as a full 3" exhaust system. These exhausts will help get the heat out, and provide more horsepower on a tuned machine.
Intake: We will be testing various types of intakes as we already found the stock to be a bit restrictive. Time will tell to see what works or what doesn't.
Clutching: These new clutches are definitely different. The helix will take some time to get made as it's a steel piece with splined. We will have our Goldstar adjustable clutch weights available shortly. Look for stage 1 kits in the near future. This will help harness the extra power we will provide.
Big Turbo: We already have a larger turbo ready to bolt on as soon as the stock turbo tuning is completed. This project will most likely end up being a full motor build with big turbo. Many variables... but we intend to make some big power on race fuel here, and have pump fuel tunes also.
Stay tuned.... literally!
opcorn:
