Battery tender not working
7.3K views 32 replies 6 participants last post by  Shonuff757va
I have a 2022 xp pro ultimate brand new and tried to connect my battery tender to the factory plug and it's not working. I put my meter on the plug and nothing. Is this fused and if so does anyone know where the fuse is? The wires from the plug go into a main harness which I think runs thru the tunnel to the back near the battery. Any suggestions?
I am assuming by your post that the battery is charged at this time. However, if you have a dead battery the battery tender will not work until there is at least a minimal amount of power in the battery. When charging a dead battery, I have to trick the battery tender by hooking the battery up to another battery to get it to start charging and then I disconnect the two batteries.
There should be an inline fuse a few inches terminal ring ends - see photo & part # below
#25 ·
My 22 model is the same way. There is finally a fix for it but I haven't taken mine in yet. I discovered this problem a week after bringing mine home then returned it to the service department for confirmation and they alerted Polaris of the problem. After many phone calls and emails there is a solution. Let me find that email with the fix info to give the service department.
If you could please find that email. Mine is at the dealership right now for that issue. I would love to be able to give them the fix before something gets messed up. Thanks. Standing by.
#33 ·
Dealer fixed in 2 hours. Text from dealer:
Good Morning Al, when inspecting your unit we found there was an outstanding bulletin for your Rzr from the manufacture. We fixed the wiring issue per this bulletin and verified everything is working correctly now!
If you have any other questions, please don't hesitate to reach back out!
Thanks
-Marley
All Out Cycles
