I tend to avoid mud as much as possible and were I usually ride it is not a problem. But with a recent trip I took to Brimstone TN I not only learned that mud is sometimes unavoidable but with a machine as heavy as a side by side you had better have a winch. That said since I expect to rarely if ever use it, I would prefer to spend as little money on it as possible. So has anybody tried the Harbor Freight "Badland" ATV winch? With a 20% off coupon I can get a 3500Lb capacity winch for under $120.00. Also do you consider 3500lb to be enough if you are not intentionally getting in the deep stuff?
