Bad TPS????
21K views 19 replies 5 participants last post by  Tuf-Skin
My TPS seems to jump around 10 points or so at idle and at WOT. Anybody had one of these go bad or display these symptoms? I am not seeing the sensor available in the parts fische.
I have one but you need to check for slop in the throttle shaft. If there is any slop in it, it will cause the symptoms you are having. I have had it happen to me, but it had more miles on it than that. The voltage numbers jump around, and it was hard to get it to repeat the correct number, and caused mine to run too rich most of the time. Shoot me a PM if you end up needing it.
Here is the same test with a volt meter hooked up. Trey at MCX is the man, He has a spare TB he is going to send me to test. According to the different writeups on here my tps is out of adjustment. I have never touch it and this thing isnt even a year old.....and it sat in the barn since october. Make me wonder if it was ever set right.
i'm not quite sure about that meter, but if it were a voltmeter i would say bad. with the motor not running sweep through the range and verify it climbs and falls smoothly (shouldnt jump at all) if you cant do it with that box, do it with a voltmeter. if it jumps around it's bad
after watching the second video with the meter, your tps is fine (may be a little out of adjustment), that box on your dash is picking up noise it looks like
