BAD ECU xp900
1 reading
16K views 22 replies 6 participants last post by  Aaherman
I have a XP900 and it seems that the ECU has taken a crap on me. The fuel pump will not fire and it does not seem to want to trigger the starter relay well. It also is making my PC5 act all wierd, I just wanted to see if anyone else has had this issue?
I've got a take off ecu for cheap if ur interested
Sent from my DROID RAZR HD using Tapatalk
#15 ·
Does anyone know if an ECU off a 2013 will work on a 2011? From what I have seen it looks to have changed in 2013.
I thought I had bad ECU ... and I stuck my dad's 2013 ecu into my 2011. It seem to work fine, but did not fix my problem (my ecu turned out to be fine).
I took mine over to another rzr and tried it. It was having all the same problems as it was in mine. Believe me I wish the ECU was not the problem. It leaves many more questions as to why it went bad.
Your welcome. Wished It would've worked out
#20 ·
Hey Malibu mike I'm trying to diagnose a possibly bad ECM right now and I'm curious what you symptoms were. I just like you only dune and the car was running great a month and a half ago after my last trip and yesterday I went to start it and no go. Just as I turned the key to "on" the efi 20a fuse blows after a few seconds of the efi relay clicking rapidly. During that the gauge cluster, pcv and gauges will not come on. Fuel pump doesn't cycle either. Checked and swapped the relays around and same results. If I pull out the efi relay and leave all other fuses and relays in and turn it to "on" the gauge cluster, pcv, and gauges all come on. Any insite on this is greatly appreciated.
This post has been deleted
