Antifreeze flush and replacement
1 reading
7K views 3 replies 2 participants last post by  Roger Lee
I have a question i cannot find!
the manual says the turbo S4 holds 11.4 quarts, after draining the system per Polaris manual, I'm only getting 6qt's out and 6qt's in during the flush, I have bleed the system and it seems to be running normal at idle, I'm just concerned the vinegar/ water flush is still in there somewhere with the 6qt's of antifreeze i added after
it was performed twice
any ideas?
You can buy the extra coolant and take back what you don't open. When it's flowing out the top air bleed screw opening when the engine is warm then it isn't going to take anymore no matter what the book says.
There are a couple of good Youtube videos on how to do this. It is a messy job. I had no issues except trying to remove that stupid bleed screw on the top front of the engine. 8MM if I remember correctly.
I have a 2015 Rzr 1K. I just changed my coolant and the manual says 4.9 qts. 11+ qts. seems like a lot. Your 6 qts. seems more normal. I would buy 2 gallons and do your coolant change.I would bet you'll have plenty even after you bleed the air out. Changing coolant was a royal PITA, but it gets done. The biggest pain is getting to the air bleed screw up at the top of the front head
