Trey .........
In considering your RzR "Kit" -- I've looked at your Web Site and the various links and have a few questions and a couple of observations ...........
In one of the videos -- The dash of the RzR is shown and below the instrument cluster are two digital gauges. They seem to read more/less the same values -- Am I to assume these were A/F ratio digital gauges - One for each cylinder ??
If so -- I may like one of these as opposed to the round A/F gauge.
Just thinking out loud here ...........
On the fuel controller - I'm assuming this is user set according to the A/F ratio throughout the RPM range of the engine. Anything on the horizion by a 3rd party manfacturer where this is automatically adjusted ?? Personally - I'm not really interested in having to continually monitor and keep adjusting.
Air intake -- Your kit places it between the seats about shoulder height as I see it in one picture. I'm concerned about the noise and perhaps an alternate location and the use of a different - Much more effective type of air filter.
Exhaust -- Sticks out farther than I'd prefer .. I realize the design limitations of the components used dictate this -- Any other alternative to shorten it up ??
Repacking of the muffler -- Does it need to be ??
Adjustment of boost. I'm assuming the turbo is user adjustable -- How and what are the boost levels -- Low/Hi this turbo is capbable of. I'm sure grade of gas/fuel used determins boost -- What are the values ??
I'm thinking -- Running pump gas and the occasional use of race gas and increasing turbo boost -- And this falls in line with a fully automatic fuel module.
Another idle thought -- A boost knob .. Dash mounted -- Perhaps an option ??
What is the sound (DB) level of the exhaust ?? I run the Oregon Dunes and I have to meet the State mandate minimum noise level.
With the plumbing of the intercooler - Can I still have my lock n ride storage box in the bed ?? Important to me as I carry essential tools/parts in it.
Depending on where you are at -- Do you have a test mule RzR with the kit on it ??
Do you attend any of the trade shows -- I've not seen your company represented at either Dunefest or Sandfest which is held on the Oregon Coast.
Thanks in advance -- For your answers ............ And for anyone else running this "Kit" -- Don't hesitate to offer your comments - Suggestions - Observations !!
Dave
Ok Dave I will try to answer some of the questions I know for you, I helped design the kit so any answers I post are legit.
Ok the guages you see in the video are a part of our up and downstream A/F race pack system. You could buy that system if you want but I don't think you would like to as it costs around 7K. Bottom line, no its not a production A/F gauge and is not available, sorry.
The fuel controller is adjustable just like the many other kits and is essentially the same box with our programming. Honestly it is the only affordable option for the RZR application, there are other options we looked into but costs increase greatly with little to no functionality increases. I'm not sure what you mean with automatically adjusted, the RZR is an open loop and has no ability to adjust on the fly. Without an O2 feedback loop and an entirely new control system its just not possible. What you're asking for in my eyes is basically a production car ECU system that is just not applicable on off-road equipment until the factory decides to support it. Let me say you can do nearly anything for a price, but the price would shock you.
The air intake we are currently hoping to work on with a local customer we met today. He is using a filter system "like" the DFR and we hope to incorporate the plumbing as an Aerocharger kit option. We have not had any filtration issues with our Dry AEM filter even in the sand. We are hoping to work with this guy also on a custom install so that his lock-n-ride will work with the tubing. We understand the tubing will not work for everyone, but it is for optimum intercooler performance. That said we will hopefully have something for you and those running the lock-n-ride soon.
The exhaust in all the pictures you see on the site are earlier versions The current version is a Gibson muffler with turn-down and does not stick out very far at all.
Gibson mufflers do not have to be repacked as far as I am aware, someone correct me if I'm wrong. It is also pretty quite but I don't have a figure for you. A turbo dampens the sound some then a muffler after that so if you have heard a Gibson exhaust I am sure its very similar.
The boost
can be turned up but we don't recommend it. That's how the whole process starts then before you know it were getting a turbo back because someone got too happy with boost. The motor is going to need some race fuel above 8psi in my opinion. I can't give you a fine yes or no for any given boost and octane requirements. It just isn't that simple but as I said its not recommended above 8 psi without race fuel. We built this kit to be a bolt on way to double your hp, that means no shims.
The turbo is going to at least double your power, if that's not enough then in my opinion you should take the proper precautionary measures and understand what you are doing. By all means it is your kit once you buy it and if you want to understand the boost control we will explain it and try to help with the process. The warranty is a "common sense" warranty, if we manufacture it incorrectly we will fix it period. This is regardless of how long you have had it. But if you abuse the kit by turning it up beyond the specified limitations we will be able to tell.
We do have our own test mule and it is the one you see pictured on the side. We are in Kansas City and the kit is currently installed. We have been testing it for year in a variety of environments. It has been in the sand and it has been all the way up to 13000ft in Colorado with no engine problems of any kind
We do attend trade shows but have not attended any specific events focused on the RZR yet due to extensive testing. However, our RZR turbo system has been represented at several drag race events in places such as Dumont by K&T Performance. We do hope to attend one of the events in Oregon this summer and maybe some other events with a tour of the western U.S. We are currently drafting our travel and marketing plans for 2009, so stay tuned.
That being said please give us a call we would love to talk to you or anyone about it.
Talking is easier than typing - 913-541-0200.
