How do I know where to set my EFI tuner? I left the settings where they were when I got it but I dont Know if it's right or if I can get more out of it.
Just need a few details. Whose EFI do you have? Year and type of RZR? Do you have a wideband A/F sensor & gauge?
Be glad to give you my opinion when I know what you have & what you are looking to accomplish.
Bart
Bart, how ould you go about checking settings on a TRinity fuel controller without a wideband guage. What do you look for if just trying changes by "feel" or do you really need a wideband to set these up?
I have the Looney Tuned EFI Tuner and I DO NOT have a wideband A/F sensor and guage. I have an '08 RZR not a sport. I'm looking to get as much HP and top end as possible without turbo.
You NEED a AFR gauge to get a decent tune or your best bet is to have a shop tune it on the dyno for the best possible tune. Your not going to get a good tune just by "feel" Run to rich or to lean and chance grenading your motor....personally I would spend the 150.00 to have someone dyno tune it properly.
Well they need to be able to tune a vehicle of the RZR's size. So any performance shop that has a dyno and deals with UTV's and quads should work. Otherwise if you pick up an AFR gauge you can get it dialed in pretty close.
you have to drill a hole in your ex close to the header or if turbod close to the turbo...then weld a bung to the pipe(bung is threded adapter for o2 sensor) a wide band reads more acurate and faster with a better range a reg one just reads plus or minus
Why spend 5000 on a turbo kit to add to an already weak power plant when i can get a webber with a turbo and twice the horse power and 10 times the realablity and a BRAND new motor for 8500? besides thats something i will spend big money on but 100+ for a fucking gauge that will only be used to program a fuel controller once isnt worth my money. besides i have the dyna fs and the remote programmer. just do it with my laptop twice as easy just let the comp do the work for you.
thats how you make adjustments but what about if the weatheir changes...you go from sea levle to 10,000 ft how are you going to know your changes are corect...thats what the wide band is about you leave it in and can see real time how things are....
Related Threads
Polaris RZR Forum - RZR Forums.net
posts
3.2M
members
152K
Since
2007
A forum dedicated to Polaris RZR enthusiasts! A great place to find rides, meet people, and exchange ideas / parts/ rzrs!
