Adding Fuse Box under the Glove Compartment
3.3K views 7 replies 5 participants last post by  EdgeXXL
So, I have maxed out what the Pulse Bar can handle so I am adding a Fuse Box with a Ciruit beaker and a relay to spread the load. In my machine (2022 Rzr Pro XP 4 Sport) it seem the best spot is under the Glove Compartment cover (removing the storage) and velcroed on top on the 10" sub enclosure.
My question is this safe enough? The pulse bar is on this cab side of the firewall as well, so I think it should be OK right?
Thanks
Likely fine as long as you don't blast it with water. Personally, I'd get a fuse box that had at least a cover on it, wrap the seam with electrical tape and mount it under the front "hood" as it were, but then I like the glovebox, keep all my permits and such there, as well as the winch control and a hat and gloves..
I believe so, or I followed the wires under the tunnel and over to the battery. Its been almost 2 years since we did that so I dont remember 100%.
I did cut a small hole for the accessory positive and negatives to come through from the "glove box" on the dash.
  • Like
Reactions: bigolbaddy
There is enough room under the center storage box by the pulse bar. I have my switch pros control box under the dash in front of the steering wheel. I have a buss bar for the switch pro under the center storage box and a key on positive buss bar and a negative buss bar located under there. I can easily add wires to all three buss bars by just removing the center storage box. Pro Armor makes a hinge so you can open and remove the lid to the center storage box for easy access to that area.
