Just to give you an idea of cost...
The Polaris Parts alone are somewhere in the $1,000 range the items below.
You should also get a new woodruff key; and now with what I know I'd get a new starter and a new bendix and along with the bushings that go in the case and the cover.
Look at Hot Rod Cranks; they had the best pricing on those.
If you want a BBK there are a lot of good options.
I like the kit that Muzzy has put together.
You'll need pistons; rings; rods...
These prices are old so just use them as a guide not written in stone.
Give FixMyToys a call and have Jeff put a kit together for you.
You can email him too:
jeff@fixmytoys.com
Call him first and let him know what you're looking to do.
- Part# QTY Description Retail, EA. Total
- 5811511 1 GASKET-EXHAUST,27 .25 MM $25.00 $25.00
- 7516734 1 SCREW $2.50 $2.50
- 7518984 4 SCR-M8X1.25X22,HX/SO $3.25 $13.00
- 3610047 1 SEAL,EXH.SOCKET $16.00 $16.00
- 5137264 2 VALVE-EXHAUST HIGH TEMP 30MM $31.00 $62.00
- 5136197 2 VALVE-INTAKE, 35MM $17.00 $34.00
- 5910329 2 SEAT-VALVE SPRING,DT800/700 $3.00 $6.00
- 5411895 2 SEAL-VALVE GUIDE $16.00 $32.00
- 5247360 1 Polaris Base Gasket $15 $15
- 3585704 2 Main Bearing (split) $16 $32
- 5412676 1 Crank Seal $15 $15
- 2203012 1 Oil Pump Assy $105 $105
- 1204082 1 Oil Pump P/U $16 $16
- 5412455 1 Oil Seal $20 $20
- 3610075 1 WP Seal $34 $34
- 5132753 4 Counter Bal. Bearing $15 $60
- P5247360 1 Polaris Base Gasket $15.99 $15.99
- 3585704 2 Main Bearing (split) $19.38 $38.76
- 5412676 1 Crank Seal $18.96 $18.96
- 2203012 1 Oil Pump Assy $126.44 $126.44
- 1204082 1 Oil Pump P/U $19.08 $19.08
- 5412455 1 Oil Seal $25.28 $25.28
- 3610075 1 WP Seal $42.99 $42.99
- 5132753 4 Counter Bal. Bearing $18.96 $75.84
- _______ 3 Break-In Oil $8 $24
- _______ 1 81.5mm Piston Ring Compressor $10 $10
- _______ 1 Gearcase Lift Plates $20 $20
- _______ 1 Assembly Lube $3 $3
- _______ 2 NGK Spark Plugs $12 $24
