7ft enclosed trailers: How the heck are yall loading them?
3.3K views 20 replies 12 participants last post by  Ohv wildcat
Hey All,
So tonight i have been going back and forth between 7x12 and 8.5x12 trailer size, the inner engineer in me says get the 7ft due to how narrow some roads and parking spaces can be, but im just curious.. how do yall load yalls UTV in the 7ft wide models? especially 64+ inch wide models.. I just dont see any room to get out in the pictures...
658318
Not answering your actual question, but there is no advantage to a 7ft over 8.5ft width trailer. The axle width is the same, it is a matter of the wheel well being inside or outside of the trailer. I have always gotten the 81/2 wide, this picture shows mine empty but you can see the wheel wells. On your picture the wheel wells are not visible on the outside due to the angle the photo was taken.
658322
I agree there is no parking/storage or wheel width advantage to a 7" 8.5' does make a much bigger hole in the air though, and for some folks that matters. I tow 9 hours one way with an F150.
Storz, that's probably a 72" in the picture. The 64" fit well enough. Heck, I'll be towing mine back home in a week. 9 hours vs 30 seconds of tight fit? I'll take the easier tow.
Now if I was only going a few hours now and again I'd go for the 8.5" too.
If it was me, I'd get the 8.5' wide, no question. Not only would it be easier to tie down/get out of the rzr, it would also allow for more wall-mounted storage. The other major thing for me is I could side-load motorcycles, which isn't possible with the 7' setup.
But I've only had open trailers. I just went from a 8.5' wide open trailer back to a 7', and already miss the extra deck width. Even with a wide open deck, visibility from the tow vehicle is no issue. That's different with an enclosed--not sure how bad visibility sucks with a full-width box behind you.
Oh, and no chance I'd cut a big hole in the floor for A/C. I'd cobble something together to tie into the existing sidewall vents. If you don't have sidewall vents, I'd say you want some. The other thing I'd consider for camping in one of these is a Maxxfan. As in, wire in a battery, replace the roof vent with a powered MaxxFan, and enjoy the fact that you can draw in fresh air at a good rate. When we're dry-camping with the RV, the Maxxfan becomes a whole-house attic fan, and moves serious air. Well worth the money for us.
#11 · (Edited)
What is your tow vehicle?
7' wide :
Creates less drag (better for lighter tow vehicles)
Does not require wide mirrors
8.5" wide :
Gives more interior space for storage, hauling and ease of loading the RZR
We bought a 7" wide over 10 years ago when I was towing with a 1/2 ton truck. It was the best choice at the time. Now that I have a 1 ton truck, I sometimes wish I had an 8.5" wide trailer. I've kept the 7" wide trailer since it's set-up the way I like it, and I don't want to go through the hassle of setting-up a new trailer. I can also tow with a lighter truck if necessary. I load a RZR that's 69" wide. It drives in fine (the door opening is 73" wide). The interior is 80" wide, so it's tight getting in & out of the RZR when loading, but not terrible. If you're a big guy this will be more of an issue for you.
Finally, get the longest that will fit your parking (since that's your limitation). An extra 2' is huge when your hauling coolers, camping gear, spares, etc. I'm amazed how quickly our extra space fills up.
If you get a trailer to fit only this machine and you get a different one in the future will you have to buy another trailer to fit that machine? Personally I would buy more than I needed (size wise) to avoid another cost in the future. Things only go up in price every year. If money was a choke point I would look for a used trailer or do with out what I really wanted till I could afford to buy exactly what I wanted. Just my 2 cents.
