41 - 60 of 94 Posts
$750?
I’m heading to bed. I need to research more to make sure I can make the 7 button fit on my 2015 900. From what I think I understand. I just buy the 2019 dash install kit but I need to make sure before I spend that much money.
Discussion starter · #43 · (Edited)
$750?
Yes 750
Yes itll work. You'll need the 2019 install kit and the older 5 button dash plastic assuming your dash is the same as a rzr 1000 which I'm pretty sure it is.
2884021 - install kit
2637083-070 - dash plastic
5262904-329 - screen to dash bracket
Those are the part numbers you'll need to complete the install.
Crap. I need 2. I’m in no rush. I’ll wait to get more in stock
Save
7 button ride command. New unit no packaging. Confirmed compatible with rzr 1000 and turbo compatibility soon to be verified.
Screen only. You'll need to buy the 2019+ install kit and plastic dash if installing on a 2018 and down rzr
750 shipped
Can pay via paypal with buyer protection but you would have to add 3% to cover the paypal fees
Do you have any units available?
Thank you very much it was worth the wait, works great and it is a 2020 version.
Save
If installing a 7 button on an 18 XP 4 1000 with or center cluster guage, I'm assuming the part numbers listed above would work for my car, is there any additional wiring that needs to be added. Is the wiring install instructions for the 7 button to go into a 19+ the same as wiring into an pre 19
Discussion starter · #55 ·
Yes. These part numbers are what you need.
5262904-329 - screen to dash bracket.
You'll also need some short 6mm screws to secure the screen to the bracket and some Philip's screws to secure the bracket to the dash.
Install instructions are the same for that kit. Leave your original round cluster plugged in also when you boot up the ride command so your mileage will transfer over to the ride command. Sometimes it takes several key cycles for it to transfer over. Sometimes you have to update or reload the software on it also for the mileage to transfer.
I can have the round cluster and the ride command plugged in at the same time? I'm assuming that not all the pins from car harness are swapped over to the new harness then?
Discussion starter · #57 ·
The 19 plus install kit doesnt touch any of the cars original harness like the 18 and down harness does. The 19+ harness is pretty much a stand alone harness
Interesting, so if it doesn't plug into the car technically how is it pulling the information for the car like speedo and rpm and other guages into the car?
Discussion starter · #59 ·
It connects only to the buss bar and tees into the diagnostic plug
Right on. Sorry im asking so many questions. So with the part numbers for the dash kit for the 18 car, it has the 5 button cutout on the dash. I'm guessing you just cut that off and open it up to accommodate the 7 button?
41 - 60 of 94 Posts
