570 won't turn over from key!
17K views 8 replies 6 participants last post by  Jonyfiver
I was out on a run stop for a break, rzr would not restart,only start if I crossed oover solenoid ,after changing solenoid ,plug , fuses still nothing at switch . Searched wire harness from switch to ECU for bad wires,found worn orange wire behind driver seat where harness splits, looks like caused by movement in harness against frame. Repaired wire started right up. Now its RZR time!
good to know.
mine did the same thing and just by coincidence my friend was there (also a 570 owner) he reached right down and wiggled the brake pressure switch on the frame and it started it right up.
Had this problem today but my loose connection was right at the sensor. Came home checked on here and voila fixed. God I love this forum.
frank was right on. good call.
Speaking of brake light problems, be sure to check that the brake light wiring running over the top of the muffler hasn't come loose and is laying on the muffler. Common problem. Insulation melts and harness shorts out.
