4wd Not engaging and no light on dash
1 reading
52K views 26 replies 14 participants last post by  185EZ
If this has already been discussed please point me in the right direction. I originally pulled the diff due to the sprague coming apart, I went through everything and I have basically replaced it all, armature plate, sprague, rollers,H clips, pin, the coil was damaged so I have now replaced the whole output cover. Put the diff back in and it will not engage nor will the light on the cluster come on. I have the rear on jack stands and the front shaft spins but nothing will engage. I had another cheap oreillys switch that I hooked up to see if it was the switch, nothing happened. I talked to a local shop today and they said it may be the sprague since there are two different ones. (a short one and a long one?) If this is true does anyone know the length difference in the two? Even if the sprague was short wouldn't it initially engage until the armature plate came off the sprague? I called the dealer who did my recalls and they say they have never heard of or had to reflash the ECU...HELP!!!
After my recall reflash they had to go back and replace my ecu due to 4wd engagement problems similar to what your having.
Mine won't engage when moving after the ecu replacement. I have to be at a dead stop. Guess it's part of the new software.
#15 ·
Update: As of right now I have found out that I have the wrong Sprague from Superatv. Matched it up with the diff number and everything. Apparently there is a short and a long version my diff number calls for the short version however that is not the case. I have a 1/4" To 5/16" Gap between the Sprague and the armature plate so it will not lock in. Superatv is supposed to have the correct one in ten days or so. So we will see if that is the fix.
I don't think that will keep the 4 wheel drive light from coming on. You might want to try reseating the big connector on the back of the speedometer. I have seen that cause this problem. It still won't work if you can't get that to light up. With the unit on the bench and all put back together put 12 volts on it. Turn the input shaft, both outputs should turn. If not something is wrong with the diff. It it works on bench and not in RZR you have a wiring problem.
I have a similar problem with my rzr. The 4wd works in H and L, but not in R. The 4wd light on the cluster doesn't turn on in any gear, but the rocker switch is lit. I'm still trying to fully diagnose it.
I unplugged & replugged the front diff plug but to no avail. I need to check voltages and resistances when I get home.
Anyone have any suggestions?
#21 ·
Alright guys so I got a 2015 rzr 900. 4x4 isn’t working. Both shafts turn, have power at the switch on Grey Wire and orange wire until you flip the switch then power is killed to the grey one. I have power on one wire at the plug for the harness side and no power on the other with the switch off. It doesn’t change at the plug when you turn the switch on snd the light in the cluster doesn’t come on. The diff is literally brand new.
#26 ·
maybe someoone here can help me, brand new bombproof diff in my 2020 turbo s4, also has hess override switch. switch to 4wd and it doesnt change on the cluster. obvisouly not working. i checked all connects all good. i have 4 volts to that plug which seems wrong (4volts to the battery bar under the hood as wells which is where it gets its power) and ohmed the plug and had 0 resistance. any tips on where to look would be highly appreciated!!! thanks!
