Has anybody put 30" tires on their 900s yet? If so did you have to modify anything for them to clear? Pictures would be great.
Wow, that's impressive. But yours is setup for mudding, technically you are not worry about the suspension bottoming out on jumps or rubbing when flexing. Have you tried jumping your RZR? If so and it did not rub then I'm sold. I wonder if it makes a difference that your tires are 8.5" wide and most 30" DOT tires are 10" wide. I trail ride and mudding is one of the last things I want to do. I like drifting, donuts, jumping, and on the occasion rock crawling. I know it sounds like I need a 1000, but I don't need that kind of HP and I would like to stay in the 60"-62" width. Again, nice RZR!bone stock the day after I bought mine. No adjustments were made, no lift, no trimming anything and no rubbing anywhere. Tires measure 32'' tall and 8.5'' wide on 18'' wheels. And it will spin them over fine, I dug 25-30ft long sets of ruts in my yard 6'' deep when I punched it in low with the stock clutching. The arms on the 900S are 1'' forward and 1'' rearward when compared to the previous 800S model.
That stance, wheels and tires look awesome!I fit 32s with Super Atv front arched A arms and adjusted shocks. Cutting it close in the rear though
