Hey guys, I have lug nuts, wheels, spacers and can match any pricing except System 3 from KJ. Here are some ways to square up an RZR because the rear is narrower than the front. Square up means that the machine is the same width front and rear. If the machine is a little wider in the rear it is still OK. Narrower can affect cornering and stability. I have used both methods below.
1. Use a wider offset on the rear wheels such as a 4+3 and a 5+2 on the front. Problem with this is rotation does not work.
2. Use wheel spacers on the rear and 5+2 or 6+ 1 wheel all the way around. No problems with this unless you use a 1" spacer on the rear instead of a 1.5". 1" spacers are weak. Rotation of tires is now possible.
