I have a 2019 turbo s with 65 hours and 460 miles. After a weekend of riding, the next morning the rzr wouldn't go into any gear easily. It took many attempts going through all the gears for it to grab anything. It would only engage by bumping the throttle which makes for an extremely rough engagement. Once it finally engages, I can shift through the gears as normal. It seems to only do it on the first shift on a cold startup. I haven't gone anywhere since the issue started but every time it's cold I go through the same thing at home. It reads the correct gear position and shifts fine after the first time it catches. Any ideas of where to start looking? The first thing I did was replaced the belt with oem and I have only ran oem belts since day 1.
Thank you in advance for any help!
